GET SMARTER: (650) 579-0210
Follow
Will a future NetSuite password change cause an issue?
If you are using the Basic authentication type (in your NetSuite connection record), when the NetSuite password (associated with the NetSuite account used to run the integration) changes, then you will need to update the password within the integrator.io connection record.
An alternative is to setup token based authentication. Token based authentication will negate the need for you to update the password associated to the NetSuite account used to run the integration. To learn how to setup token based authentication, see this article
Was this article helpful?
0 out of 0 found this helpful
Powered by Zendesk
