GET SMARTER: (650) 579-0210
Follow
How do I switch to token-based authentication?
To use token based authentication, login to integrator.io and follow these steps:
  1. Go to connections page and click on the NetSuite connection
  2. Click on ‘authentication type’ and change to token based.
  3. Use the field level help to obtain details on populating the necessary fields such as token ID and token secret. You will likely need to contact NetSuite support to get the necessary values for token id & token secret.
Was this article helpful?
0 out of 0 found this helpful
Powered by Zendesk
