GET SMARTER: (650) 579-0210
Follow
Message is not syncing or Blank Messages are synced
Definition
There are times when the Auth Token which connects Google and Netsuite expires and needs to be refreshed. To do this, you need to re-grant the license through the CloudExtend Setup Wizard in NetSuite.
Steps To Resolve
Verify OAuth token is valid - [Only way is by Re-validating the OAuth token from Setup Wizard]
Note: this should be done only by a Google and NetSuite Administrator
Steps for accomplishing this task is similar to the one documented here.
Was this article helpful?
0 out of 0 found this helpful
Powered by Zendesk
