GET SMARTER: (650) 579-0210
Follow
Gcal: Why do some events have the Organizer field set to "-System-"?
Events created by the CloudExtend Google Calendar Import on a scheduled basis will have the value for "Organizer" set to "-System-".  This is because NetSuite does not let us override the value of this field to someone other than the event creator when importing events on a scheduled basis.  We are able to set the "Owner" field to the correct value for the imported event, but NetSuite will not let us change "Organizer" to be the event owner as well.  Please note that if you run the CloudExtend Google Calendar Import on-demand the Organizer field will be set to your login name, and you will be invited to the event!
Was this article helpful?
0 out of 0 found this helpful
Powered by Zendesk
