GET SMARTER: (650) 579-0210
Follow
Options Menu in SmartClient
You can set preferences for how the SmartClient behaves from the Options window. These options control handling security on a shared computer, the size of data tables, whether you connect to your live account or beta or sandbox accounts, and more.
To set preferences:
  1. In the SmartClient toolbar, click Options.
  2. In the Options popup, under Security, you can set the following options:
    • Click Clear next to Clear Your Stored Credentials to remove your login information from the SmartClient. This is recommended if you use a shared computer. In the Celigo menu, choose Re-login to re-enter your credentials.
    • Check Treat Warnings as Errors to prevent a record from being added or updated if NetSuite presents a warning.
      In NetSuite, warnings are usually presented as popups that you must acknowledge before an action is completed, such as an inventory warning.
      If you leave this box cleared, records or transactions with warnings are still added or updated, and you receive the warning message at the end of the add/update.
    • Check Ignore Read-Only Fields to avoid errors if you have entered data into a field that is read-only in NetSuite. The data you have entered is ignored, and the read-only data in NetSuite remains.If you clear this field, you will receive an error when trying to update data in a read-only field.
  3. Click Caching and Performance on the left side of the window to set the following options:
    • Click Refresh to refresh cached data from NetSuite such as custom fields,custom records, and drop down values. You also must clear yourmeta data cache when you have made new customizations in your NetSuite account. The next time the SmartClient requires the custom data, it will reload your information, including new custom fields or records. Note that there are alternative ways to refresh cached data selectively. These include:
      • The Refresh option in the Custom Records menu.
      • The Refresh button next to the custom fields list in the Templates Wizard.
      • The Refresh Drop Down Items option on the cell right-click menu.
    • In the Search Page Size field, enter the maximum number of records or transactions per page to be returned when you perform a search. When a page of the mentioned size is retrieved, user is prompted for display of the next page size of results.
    • In the Refresh Table Size field, enter the maximum number of records to be returned when you Repeat Last Search.
    • In the Add/Update/Delete Request Size field, enter the default number of rows in the table used to Add Records Using Template.
    • In the Update Line Items in Batches, it is recommended that this option is checked when user generally updates more than 40 line items per record. When this option is checked, SmartClient updates all line items per record in batches of the mentioned size and posts the status of the updated batch before attempting to update the next batch of line items. When this option is unchecked and user has large number of Line Items per record to update, the application will take longer to update the line items and in case of validation errors on any of the line items, will prevent updating of the other selected line items. Note, when this option is checked, all errors on line items will be ignored until all selected line items are updated.
    • In the Upload records ignoring lines that fail local validation, check this option to ignore validation errors while updating line items. This option needs to be checked if you do not have the Update Line Items in Batches turned on (which will automatically ignore validation errors) but still want to ignore validation errors and continue updating all selected line items.
  4. Click Connectivity on the left side of the window to set the following options:
    • In the Connect to NetSuite field, select which version of your account you want to connect to.
      Select Production to work with your live data. Select Beta to work with data in a beta version of NetSuite when available, such as when a new release is being phased in. Select Sandbox if you have purchased a sandbox account for testing your NetSuite data and want to work in this test account.
    • Check the Work Offline box to enter data in the SmartClient while offline.
      This disables automatic validations for dropdown fields.
    • In the # of Times to Automatically Retry field, enter the number of times the SmartClient should try to login to NetSuite if the connection is not made on the first try.
    • In the Seconds Between Each Retry field, enter the number of seconds between each attempt to contact NetSuite if a connection cannot be made.
  5. Click Ok to save your preferences.
Was this article helpful?
0 out of 0 found this helpful
Powered by Zendesk
