Delete a value completely from a field (setting it to null)
Here's the solution to update a field to a blank (null) value.
- Set the value of the field that you want to make null to :empty: and then run your update.
Note:
- Leaving the cell empty does not update a field value to blank.
- This works only for body level fields.
I'm trying to clear the contents of a field in Netsuite
Using your help: How Do I Delete A Value Completely From A Field (Setting It To Null)?
I used the :empty: this did not remove the values in the fields.
